VERSION 2 Connection issue [fixed]
edited August 10 in Problems Now Fixed
Hi I have recently got a version 2, everything works fine on my home router, but I have two seperate 4G routers, as it will be used where there is no wired internet connection. The rx shows on the list and map, but when trying to connect it shows this page not found.
Any ideas.
Dave ( G3GPO TEST )
  • It possible CGNAT isnt playing nice.
    Some Carriers might also block proxy based traffic too.
  • Showing on the rx list/map may be leftover from when you were last successfully connected through your home router. It takes significant time for a Kiwi to disappear from the list/map if it is no longer responding to the polling conducted by kiwisdr.com. It is not instantaneous.
    Here's something to try. It is related to this Mongoose update issue we've recently had. On the admin "update" tab, bottom of the page, set the "Disable recent changes?" switch to "Yes" and restart. See if that fixes it. If it does please let us know.
  • HI I am now unable to use the admin interface because as, after a few seconds it keeps looping around server has closed connection, a 60 second timer comes up, and the same thing happens. Note this is also occuring when on the main router as well as via the 4g router.
  • You must have re-flashed to a very old version where this admin looping problem occurs. Email the admin password to support@kiwisdr.com and I can fix it.
  • Thanks will do.
  • Unfortunately, this is had not been able to be resolved. So Im back to square one. My next question is any one in the UK accessing via a 4G router. If so what type and which network. And secondly what settings if any were made in the router. Im looking to instal a few on remote sites if I can get this resolved.. Thanks in anticipation.
  • Success today,Thanks to JKS after a adjustment of the Ethernet interface MTU to 1344 (network tab). 4G connection now possible. v 1.819
