Why no registration at rx.kiwisdr.com?
Hi all,
Today I had to reinstall my kiwi-1 because of a crash or something like that. Now, when I try to register at rx.kiwisdr.com I get the following message:
Error, you must first setup a valid Kiwi connection URL on the "connect" tab
I'm sure I did provide a valid hostname in the fields:
  • Domain name
  • Specified IP (with my ip-number).
I guess that should be enough. I do not use a reverse proxy ( I never have used that by the way).
So what could be the problem? Thanks in advance.
  • edited August 7
    Did you automatically or manually upgrade to v1.816 or v1.817 ?
    All stations with v1.816 do not respond to some browsers, and 817 is solving the problem.
    T
  • Hi,
    Thanks for your reply. The Kiwi is manually upgraded to 1.802, from that version tot the latest (1.817). With another browser, I still can't make it register. This is very strange.
  • I guess I found it. After installed it is obviously necessary to click "public IP" in the connect tab, and then it asks for a restart. Now it is solved!
  • What is the line selected in green, "Domain name" or "Specified IP" ?
    Before the initial crash, you were using option "Automatically install software updates = YES" ? (Admin/Update tab)
    Better wait for @jks, my questions/answers may spare one day/night cycle with the other hemisphere. 😄
    T
  • OK, we posted at the same time. Fine !
  • But it is not listed currently and not sending public registration info to kiwisdr.com
    Are you sure you still have registration set to "Yes" on the admin public page?
