does ipv6 prevent registration? [fixed in v1.100]
[ Hi RJ. The way you pasted the log in your original question really messed up the forum software. So I had to delete the question and re-post it myself. This forum software is not the best unfortunately 8-| ]
hi,
does having an ipv6 address prevent from registration?
Sat Jul 1 19:06:58 2017 0:00:35 .... DDNS: private IPv4 <192.168.178.20> 0xc0a8b214 /24 0xffffff00
Sat Jul 1 19:06:58 2017 0:00:35 .... DDNS: private IPv6 <2003:80:ad1e:1900:b2d5:ccff:fe57:189a> /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Sat Jul 1 19:06:58 2017 0:00:35 .... DDNS: private IPv6 LINK-LOCAL <fe80::b2d5:ccff:fe57:189a%eth0> /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00:
Sat Jul 1 19:06:58 2017 0:00:35 .... UPDATE: version 1.99 is current
Sat Jul 1 19:06:58 2017 0:00:35 .... task update_task:P2:T22 exited by returning
Sat Jul 1 19:06:58 2017 0:00:35 .... DDNS: public ip 91.41.116.40
Sat Jul 1 19:06:58 2017 0:00:35 .... auto NAT is set false
Sat Jul 1 19:06:58 2017 0:00:35 .... task dyn_DNS:P2:T02 exited by returning
Sat Jul 1 19:06:59 2017 0:00:37 .... sdr.hu registration: "ERROR (your IP does not match URL, 91.41.116.40 != 2003:80:ad1e:1900:b2d5:ccff:fe57:189a)"
Sat Jul 1 19:07:07 2017 0:00:44 .... TIMEZONE: lat/lon from sdr.hu config: (51.161236, 6.996694)
Sat Jul 1 19:07:07 2017 0:00:45 .... TIMEZONE: for (51.161236, 6.996694): utc_offset=3600/1.0 dst_offset=3600/1.0
Sat Jul 1 19:07:07 2017 0:00:45 .... TIMEZONE: "Europe/Berlin", "Central European Summer Time"
Sat Jul 1 19:07:07 2017 0:00:45 .... task get_TZ:P2:T03 exited by returning
Sat Jul 1 19:07:13 2017 0:00:50 .... [00] isLocal_IP: flg=0x18 fam=10 socktype=1 proto=6 addrlen=28 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d
Sat Jul 1 19:07:13 2017 0:00:50 .... [00] isLocal_IP TRUE IPv6 remote_ip 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d ip_client 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d ip_server[IPv6] 2003:80:ad1e:1900:b2d5:ccff:fe57:189a nm /64
Sat Jul 1 19:07:13 2017 0:00:50 .... [00] PWD admin: config pwd set TRUE, auto-login TRUE
Sat Jul 1 19:07:13 2017 0:00:50 .... [00] PWD admin: config pwd set, but is_local and auto-login set
Sat Jul 1 19:07:13 2017 0:00:50 .... [00] PWD admin allow override: sent from 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d
Sat Jul 1 19:07:39 2017 0:01:17 .... [00] ADMIN connection closed
Sat Jul 1 19:08:05 2017 0:01:42 .... [00] isLocal_IP: flg=0x18 fam=10 socktype=1 proto=6 addrlen=28 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d
Sat Jul 1 19:08:05 2017 0:01:42 .... [00] isLocal_IP TRUE IPv6 remote_ip 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d ip_client 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d ip_server[IPv6] 2003:80:ad1e:1900:b2d5:ccff:fe57:189a nm /64
Sat Jul 1 19:08:05 2017 0:01:42 .... [00] PWD admin: config pwd set TRUE, auto-login TRUE
Sat Jul 1 19:08:05 2017 0:01:42 .... [00] PWD admin: config pwd set, but is_local and auto-login set
Sat Jul 1 19:08:05 2017 0:01:42 .... [00] PWD admin allow override: sent from 2003:80:ad1e:1900:1cd0:6ed8:3b26:466d
Sat Jul 1 19:09:02 2017 0:02:40 .... sdr.hu registration: "ERROR (your IP does not match URL, 91.41.116.40 != 2003:80:ad1e:1900:b2d5:ccff:fe57:189a)"
Sat Jul 1 19:11:05 2017 0:04:43 .... sdr.hu registration: "ERROR (your IP does not match URL, 91.41.116.40 != 2003:80:ad1e:1900:b2d5:ccff:fe57:189a)"
sorry for the inconveniences.
nslookup -query=AAAA kiwisdr.shjn224ludslv1s5.myfritz.net
Non-authoritative answer:
kiwisdr.shjn224ludslv1s5.myfritz.net has AAAA address 2003:80:ad1e:1900:b2d5:ccff:fe57:189a
best regards
robert (db1jj)
If you need a ipv6 connection there are ways to get one via a tunnel: https://en.wikipedia.org/wiki/List_of_IPv6_tunnel_brokers
on ipv4 i have here the normal nat setup. with port forwarding of port 8073/tcp to 192 168 178.20 on the internal net.
on ipv6 i get in the moment the 2003:80:ad1e:1900::/56 net (56 is netmask) from my provider and the kiwi is on
2003:80:ad1e:1900:b2d5:ccff:fe57:189a in the moment.
