Some servers always disconnect after 10 seconds with kiwirecorder.
Some servers always disconnect after 10 seconds with kiwirecorder. I have --tlimit=20 but for about 1 in 10 servers it always disconnects after 8 to 10 seconds. In the log you typically see a "too_busy" at the end. But if you connect using the regular browser there is no such disconnect.
With most servers this does not happen. I have a list of seven servers where it does happen. I'm not including the list here yet because I don't want to possibly subject them to a lot of adverse traffic. It happens with about one in ten servers. They seem to have late version software, such as 1.815.
It also happens with sdrpp (sdr++).
Anybody know why this is?
These Kiwi most likely have the setting "Number of simultaneous channels available for connection by non-Kiwi apps" set to "None" (admin "connect" tab).
The algorithm for determining if a connection is a "bot" connection takes a little while to run (about 10 seconds). And one consequence of this is the behavior you describe. I tried this myself just now to confirm.
Ah. Got it. Thanks.
This 10 second delay is unfortunate. But it's essential that the algorithm has no false positives.
