GPS Admin screen
                    I dont really understand what the screen is telling me ? I will enclose a screen grab, but my questions are..
                            The antenna here isnt in a great location, but I would expect a fix here,... as I dont know what to expect and haven't seen anything in the user guide any help appreciated.
Enable GPS set to YES
Ch 0 to 11 mostly blank except Ch0
ACQ (assume acquired GPS) YES
tracking blank
Good blank
Fixes blank
run 59:41:28
TTFF blank
GPS time blank
ADC clock 66.666070 (0)
Lat blank
Lon blank
Alt blank
Map blank.
Is this fixed ?
What should it display when fixed?
Timing seems OK for WSPR having checked earlier.
Thanks Dave M0TAZ
https://forum.kiwisdr.com/uploads/Uploader/8b/a375f7026e72f3e183a8d1b6f0c4a4.jpg
I've moved the Antenna outside and now see 1 to 3 sats and have a GPS location showing with an associated map.
Still don't fully understand how the GPS has been implemented, the time for instance is stopped at 19.23.13 so I guess it's now lost its fix?
Indoors I would expect 3 to 5 fixes as I get on the QRP Labs WSPR txm using the internal antenna. I understood these units have the same GPS chip, so should really perform in a similar way.
I will try another active antenna, see if that changes anything but don't really understand why it's not that sensitive, most modern GPS receivers are amazingly sensitive these days?
Regards Dave M0TAZ
I have still problems getting GPS running ...
Can somebody suggest a better GPS receiving OUTDOOR antenna, as I hardly can copy more than two GPS sattelites at a time with the supplied active GPS antenna...
I understand as the GPS-functionality in software is not as clever as in GPS (mine is 6years old and captures easily constant 10 sattelites at a time)....
If one sattelite is lost, it needs about 2-3minutes until a new one is found... with RSSI hardly reaching more than 350 (SNR just 16 or 17)
So not to wait so long, I need a really good GPS antenna outside not to loose satellites, found earlier, because it takes so long to find a new one...
Unfortunately there is no spec of the supplied antenna, so I really don't know what to search for, for considerable improvement, which is really necessary to get GPS running.
I have the shack in the basement - there is no GPS at all...;-(
But even on the first floor (under the roof) - no luck with sufficient GPS reception... so outdoor is a must.
No trees - flat terrein... my very old phone sees 10...12 satellites at once outside... so there is headroom for improvement with a good outdoor GPS antenna....
Any suggestion? And where to buy ? Ebay?
Ulli, ON5KQ
One possibility is indeed to move the Kiwi completely outside in my Gardenhouse. Then GPS antenna can be installed easyly outside...
But it needs some more work of installation necessary powerlines
The outdoor GPS antenna seem to be also a good deal ...
What I also wonder is, whether I might have additional interference sometimes from Wifi routers arround. Sometimes I get strange SNR-values in the admin panel, like 82 in the SNR colomn... that seem to be a spike coming from some noise ?!
Certainly I need to test more to find a good solution.
Ulli, ON5KQ
