Issue with "User exemption password" [fixed, config issue]
Hello,
I have set in the "Control" tab a "user exemption password" to be able to switch my anrennas when I am outside.
But when I log in to the Kiwi with the "url:8073/?pwd=password" or "url:8073/?password=password" I have no access to the RF attenuator nor the antenna switch.
I am running Kiwi 2 with the V 1.810 firmware and I am trying to acces from an iPhone X with Safari.
What am I doing wrong ?
73 F5LFE
I'm having trouble too. Checking..
Additional info :
the time limit exemption does work but not the attenuator nor the antenna switch
Actually, it does work for me. I had the antenna switch in debug mode.
Make sure both antenna switch and attenuator have their permission menus set to "local connections or user password only". Then restart the server.
For the attenuator this is on the admin config tab, scroll down on the left side, menu called "Allow RF attenuator switching by". For the antenna switch it's on the admin extensions tab, antenna switch selection, "Allow antenna switching by" menu.
I did not set the RF attenuator correctly so I did it and restarting the server fixed both problems.
Many thanks for your help.
VY 73 F5LFE
