v1.807,808
Instructions for the Debian 11 upgrade procedure described below are here: http://kiwisdr.com/quickstart/index.html#id-D11-upgrade
From the CHANGE_LOG file:
v1.807,808 April 10, 2025
  Admin backup tab: Added button to create a Debian 11 upgrade SD card which includes all
    customizations from the current Kiwi. Intended to be used by Kiwi's still running Debian 8.x
    Greatly simplifies the upgrade process by automating these formerly manual tasks:
      Checks for sufficient free disk space.
      Downloads Debian 11 image file from kiwisdr.com with integrity check (checksum).
      Writes image to SD card.
      Copies configuration from Kiwi's kiwi.config directory to SD card.
      SD card is now ready to be use to re-flash this Kiwi to Debian 11 on the next restart.
      Including if you were to immediately restart after the sd card creation completes.
    => Everyone is strongly advised to upgrade to Debian 11 from Debian 8.
      At some point we will no longer provide software updates to Kiwi's running Debian 8.
  Complete rewrite of the admin webpage grid & location processing code. (thanks studentkra)
  FSK extension: Added preset menu. Complements the existing ability to set presets in the URL.
  Reduced minimum name/callsign (ident) length from 16 to 8 characters. (thanks LIN)
  Admin status & antenna switch configuration page now displays antenna status. (thanks LIN)
  Updated to EiBi-A25 database. (thanks jgreentn)
  External extensions being present will always cause a compile from source. (thanks DL3LED)
HB9TMCTremolatnitroenginestudentkraIK8SUTjimjackiiG4ZFE
  • edited April 10
    Just noticed this with a couple of public Kiwis that have updated to v1.807. The waterfall smears when zoomed all the way into WF14 (which I use often to watch and track down offsets). It's fine from WF13 and out. These Kiwis are running 4 channel mode. I haven't yet updated mine to v1.807 so not sure if it affects 3 channel mode.
    Edit: Yes, it also affects 3 channel mode Kiwis.
  • Thanks. I had to rebuild the FPGA code for this release. Something I haven't done in quite a while. This problem seems to be related to that.
    edited May 4
    Yep, a typo made in the Verilog code last July if you can believe that. Didn't show itself until I built v1.807. Fixed in v1.808..
    nitroengine
  • GOOD MORNING
    I probably have a problem understanding the update to debian11:
    1- I have a kiwi v.1 Debian 8.5
    2 - I created an update SDcard using the procedure in the [backup] tab, operation completed without errors.
    3 - I turned off the Kiwi and then I turned the power back on with the SDcard but the device does not update.
    4 - in the [concole] tab ---> [monitor build progress] nothing appears except:
    CONSOLE: open connection
    root@kiwisdr:~/KiwiSDR# tail -fn 500 /root/build.log
    ======== checking for update
    Thu Apr 10 10:51:13 UTC 2025
    ======== version check complete
    ^C
    5 - in the [status] tab you can see that the debian version has remained at 8.5
    [KiwiSDR 1, v1.808, 4 SDR channels, 12 GPS channels | Uptime: 0:20:59 | UTC: 11:10 | Local: 13:10 Europe/Rome (CEST)
    Debian 8.5]
    QUESTION:
    a: Is it not possible to update my Kiwi1?
    b: Do I need to give any specific command?
    Thanks in advance for any help.
  • Hi Fabrys,
    You may be in the case where you need to locate the boot button on the Beagle Bone, hold it and then finally apply power to the Kiwi so that the flashing process begins, as described here :
    KiwiSDR Operating Information
    I hope this may help...
  • Hi, F5AFY
    Thank you for the information, it seems that everything went well as attached image even if the update is v1.804, now I have to update it to the latest version.
    F5AFY
  • Thanks. I wrote some instructions about the process here that also mention the possibility of having to use the boot/user button: http://kiwisdr.com/quickstart/index.html#id-D11-upgrade
  • FYI @jks, after upgrading smoothly -> v1.807 -> v1.808 (I was already D11.11), I did the usual backup SD card without problems, I got to the Log tab, and saw the following ("SYS_PANIC"). Everything is working fine, though.
    Thierry
    Thu Apr 10 13:19:27 02:38:33.697 ... [00]  sd_backup: kiwi.platform=0 <cd /root/KiwiSDR/tools; cp /etc/beagle-flasher/beaglebone-black-emmc-to-microsd /etc/default/beagle-flasher; ./beaglebone-black-flasher.sh>
    Thu Apr 10 13:19:27 02:38:33.697 ...    rx_server_kick KICK_ALL rx=-1
    Thu Apr 10 13:19:33 02:38:39.198 ...    SYS_PANIC: "led write delay_on" No such device (dev/leds.cpp, line 124) No such device
    Thu Apr 10 13:19:32 02:41:44.119 ...   L GPS correcting time: 13:19:32.190 (+18) UTC 13:22:38.043 deltaT -185.853 SET
    Thu Apr 10 13:31:02 02:50:08.635 ...   L GPS correcting time: 13:31:02.070 (+18) UTC 13:31:02.576 deltaT -0.505 CHECK
    edited April 11
    I think this is a conflict between who controls the LEDs during the sd card backup script running. I believe it's on my list of things to fix.
    Update: Okay, fixed for the next release.
    jimjackii
  • Sorry for the curiosity:
    My Kiwi v1 after the update with the SD card has debian 11.11
    while the high Kiwi v.2 after the 1.808 update has debian 11.9
    is everything normal or do I need to do some update that is not clear to me, taking into account [if I'm not mistaken, as I didn't open the case and therefore I'm going from memory] that the Kiwi 2 does not use an SD card for the update.
    edited April 12
    You can update the Debian minor version number from the command line (just not the major version number). Open the admin console tab. Then type:
    pkup (package update)
    pkug (package upgrade)
    reboot
    This should upgrade you from Debian 11.9 to 11.11. Each of the "pk" commands will take several minutes to run.
  • Thanks for the information
  • Looks like mst stops the console connection so you cannot enter the subsequent commands ?
    edited April 12
    @VK3KHZ Thanks, fixed. I'm so used to doing those things via an ssh connection. Didn't help that I had been up since 3AM yesterday! lol
  • I just did this for a customer (D11.9 to D11.11) using the admin console and it took 30 minutes. With the server running and active user connections.
  • Thanks John !
