Settings for colormap
Hello,
I have another small problem.
I have set "Kiwi" in Settings -> Config -> Colormap.
However, when I start the connection to KiwSDR, it always starts with "CSDR".
This also happens if I switch to "Kiwi" in the browser, delete the browser cache and reconnect to KiwiSDR later.
Surely this is not intentional?
Regards, Steffen
The admin page, config tab, colormap setting only applies if no override exists in browser storage from a previous visit to the particular Kiwi. Usually the first time you visit it (or after a storage/cache clear).
If it's starting with csdr just change it to kiwi on the user WF tab (bottom left colormap tab) which will change browser storage and apply to the next visit.
You can bring up the browser console and check storage to see the actual current setting.
Ok, thanks John.
I have now tested it again with Chrome - it works as you described. After clearing the browser cache, it starts with the configured colormap (here "Kiwi"), otherwise with the colormap set in the browser.
Strangely enough, the same procedure with Firefox always starts with the colormap "CSDR". I now have to look at this with the debug console.
Regards, Steffen
