"Filesystem is FULL!" error [fixed]
Hello,
I am trying to update my Kiwi (it has been running for a decade) and for the first time I had the "Filesystem is FULL!" error appearing. I can no longer update.
The offending directory appears to be .git inside of Beagle_SDR_GPS:
root@kiwisdr:~/Beagle_SDR_GPS# pwd /root/Beagle_SDR_GPS root@kiwisdr:~/Beagle_SDR_GPS# sudo du -h --max-depth=1 . | sort -rh | head -n 10 1.9G . 1.8G ./.git 50M ./extensions 34M ./unix_env 25M ./pkgs 12M ./web 6.0M ./rx 4.2M ./verilog.Vivado.2022.2.ip 2.0M ./tools 1.4M ./dx
can I go ahead and empty that directory or should I do anything else?
thanks
If this Kiwi is accessible from the Internet easiest thing is to email the URL and admin password to support@kiwisdr.com and I'll fix it for you.
Is what you show being done from the admin console or a direct ssh connection? If ssh I can give you manual rebuilding instructions. But if admin console do not remove the .git directory. You'll never be able to update again.
I have access to both the console and ssh. In any event, I sent you an email.
regards
Alain
