Bad parameters ?
edited May 2017 in Problems and Issues
I have had 2 times this in my log :
Tue May 30 12:09:35 2017 1d:07:18:36 01.. 1 W/F BAD PARAMS: <?> ####################################
Tue May 30 12:09:35 2017 1d:07:18:36 01..  1   SND BAD PARAMS: <?> ####################################
J-Luc
    edited May 2017
    Yes, anytime the sound or waterfall processes receive an unrecognized command on the web socket stream a message is logged. But there is also a bug I recently fixed where _any_ command received after the server thinks the connection is "closed" is logged. This is incorrect and there will be a fix in the next release. You will occasionally see random stuff logged. Unless it is causing you a problem you should not worry about it.
    f1jek
  • Ok, thanks.
    I don't worry (as it works perfectly), I am just curious :-)
