Setting up the connect menu
Now I have found the ip address of my sdr where do I enter this in the connect menu
Which IP address ?
Your internal network (probably 192.168. xxx.xxx), or the outward facing public IP, which will probably change unless you have paid for a fixed one.
You will also need to setup your router for port forwarding.
Most of the information can be found in the on-line "KiWi sdr operating information" document.
Thanks for the info
