wflor/wceil scale have a deficit setting?
  • That's not how it works.
    When you're in "aperture = auto" mode the signal strengths in the waterfall define where the WF min/max points are defined. WF floor/ceil lets you add/subtract amounts onto that. Scroll down in the WFn tab to see the exact calculation.
    So two different Kiwis will show different results if the signals are not the same strength.
    If you want to set absolute values use the "aper = man" mode to set WF min/max directly.
