v1.704 update
So I released v1.704 today. But with only a couple of exceptions it failed to install anywhere. And I don't understand why. All of my testing installed fine. Not even Kiwis still building from source code updated properly.
I need admin access to someone's Kiwi where there is a failed install error message in the Kiwi log or the build.log file. Please email to support@kiwisdr.com. Thanks
  • Both of mine are locked up.
    Update tab shows updating to 1.704.
  • #2 finally started working.
    #1 indicates updating to 1.704 when I click on "Check for Updates"
  • I emailed Admin info.
    Thanks for everything.
    Rich
  • Follow up for my #1 Kiwi - http://k9dxikiwi.proxy.kiwisdr.com:8073/
    Be aware that it is configured to auto forward to my #2 kiwi.
    From the Admin page Log - It appears to be restarting every 5 minutes. SNR 0/0. Check for Updates indicates it is updating to 1.704 from 1.703.
    Admin info emailed to you.
  • After watching it reboot every 5 minutes for several hours, I tried something.
    On the update tab I clicked on 3 things - Automatically check for updates? NO, Automatically install updates? NO, Disable recent changes? Yes
    The kiwi restarted and is functioning normal on 1.703
    Pennkichi2
  • Still running v1.702, clicked "check now" and it showed "Git clone damaged!".
    I closed the Admin interface, reopened it a little while later and clicked "Check now" again and now it displays "Available version v1.704".
    I have not attempted to force a build yet. The Kiwi is currently running as normal. I have a backup from several versions back I can restore it with if needed.
  • edited November 2024
    I just had a ~30 second power outage several minutes ago. After the Kiwi restarted (it never displayed an update screen), it's now showing it's on v1.703. I never forced a build. Showing "Git clone damaged!" when "Check now" is clicked.
    Repeating what I did above, exiting out of the Admin interface and coming back and clicking "Check now" again, it now displays "Available version: v1.705".
    I have not yet attempted to force a build. As far as I can tell, the Kiwi is still working as normal.
    This is a KiwiSDR 1 still running Debian 8.5. I plan to update it to Debian 11 sometime this winter.
  • See the recent announced post for a solution to this problem.
    nitroengine
