TDoA not working
Hi there,
Is there a recent issue with TDoA?
I have tried multiple browsers and also tested outside of my own WAN but i cannot get it to work for around 2 weeks now.
You select stations and click submit but the green arrow never spins.
Eventually times out with a kiwirecorder error.
Thank you,
Chris.
Hmm, works for me. What happens when you try this standard setup?
http://your_kiwi:8073/?ext=tdoa,DL2NI,oz1aef,f1jek,DCF77,z:5,lat:50,lon:9,sample:15,hosts:,refs:0:8,submit:&keys=y
That works.
Any idea what the issue may be?
Almost certainly you're using a sampling station that is throwing a kiwirecorder error for some reason. Like all the channels are full etc. Hold the shift key and click on the green speaker icon to see if you can connect and see the waterfall preview for each one.
Post a screenshot here or to support@kiwisdr.com if you continue to have trouble. I'm not seeing any general errors in the TDoA server logs.
