Inactivity Timer Setting
Is the Inactivity Timer setting in minutes or hours?
While I'm on the configuration topic, is there a document that gives more detail what the different admin configuration settings mean?
Thanks
Steve, NA5C
Thanks
Steve, NA5C
Indeed, I also didn't find any explicit info on that. But why not quickly try it out? I entered 1, and less than 1 minute later the stream stopped, and I got the following message:
Sorry, this KiwiSDR has an inactivity timeout after 1 minutes.
Reload the page to continue.
So it's clear the timeout value has to be entered in minutes.
BTW, since the actual elapsed time in my case was significantly less than one minute, I suspect that the timeout value is only checked at full minutes and therefore an uncertainty of up to 1 minute can arise. ;-)
Thank You, dl7awl
I appreciate your help.
73
Steve
The field title says
... (min, ...
which is meant to mean "minute".
