Black listed IPs: What message, if any, do they receive when trying to connect?
I just wonder how communicative we are, when black listed IPs try to log on to our KiwiSDRs?
73s
Henrik
  • Ideally, there should be no response at all for visitors with a blacklisted IP, and the system should be completely "invisible" (like non-existent).
    As far as I can test with my own kiwi (using a VPN in order to appear with an external IP after having added that very IP to the local blacklist), it seems to behave exactly as described.
  • DL7AWL, brilliant idea to test with VPN!
    thanks for info!!
    BR
    Henrik
  • If someone uses a VPN to connect to KiwiSDR will it show location as blank?
    I get those a lot....
    How to black list all of 77.0.0.0 ?
    like this : 77.0.0.0/8 ?
    Thanks for help.....
  • edited July 2024
    77.0.0.0/8 would be
    77.0.0.1 to 77.255.255.254.
    But such a big range is usually not neccessary. You can do a IP whois to see which range belongs to an IP address.
  • This IP Address didn't say where it is....
    89.242.87.16
    I looked it up with whois and said :
     United Kingdom of Great Britain and Northern Ireland [GB]
    What does KiwiSDR use to do lookup? It didn't work for KiwiSDR ? Why ?
