Firmware won't update past 1.67 [corrupted Beagle/Debian filesystem]
                    I've been away a couple weeks and I noticed the firmware hasn't progressed past 1.67 despite several subsequence releases.  I've had autoupdate set all along, Forcing a check shows 1.82 is the current version, then force build and the blue banner saying server will restart shows up on most pages.  The log finally shows a build error.  What are my options?  Log below.
                            UPDATE: version changed, current 1.67, new 1.82Thu May 11 16:54:49 2017 0:00:06 .... UPDATE: building new version..Thu May 11 16:54:50 2017 0:00:07 .... UPDATE: error in build, non-normal exit, abortingThu May 11 16:54:50 2017 0:00:07 .... task update_task:P2:T19 exited by returningThu May 11 16:55:10 2017 0:00:27 .... [00] isLocal_IP: flg=0x18 fam=10 socktype=1 proto=6 addrlen=28 ::ffff:192.168.0.104Thu May 11 16:55:10 2017 0:00:27 .... [00] isLocal_IP TRUE IPv4/4_6 remote_ip ::ffff:192.168.0.104 ip_client ::ffff:192.168.0.104/0xc0a80068 ip_server[IPv4] 192.168.0.110/0xc0a8006e nm /24 0xffffff00Thu May 11 16:55:10 2017 0:00:27 .... [00] PWD admin: config pwd set TRUE, auto-login TRUEThu May 11 16:55:10 2017 0:00:27 .... [00] PWD admin: config pwd set, but is_local and auto-login setThu May 11 16:55:10 2017 0:00:27 .... [00] PWD admin allow override: sent from ::ffff:192.168.0.104Thu May 11 16:55:21 2017 0:00:38 .... UPDATE: force update check by adminThu May 11 16:55:24 2017 0:00:41 .... UPDATE: force update check by admin
