Audio stream to an Icecast server
I'm trying to stream an audio feed to an Icecast server.
Best for me would be doing this on the Beagleboard itself, but I think there couldn't be enough CPU left for audio encoding.
So, i tried to do it on a raspberry PI from the same local network, using the kiwi_nc utility, shell piping to an MP3 or OGG encoder, and than to Ezstream (a shell Icecast source client), but I've got no success (broken pipes).
Am I on the right path ? Is kiwi_nc actually outputting a raw audio feed ?
Any help would be apreciated.
Thanks a lot :)
  • edited August 2022
    what string do you feed to kiwi_nc
    cli args that is
  • you might look at this:
  • Hi Jim,
    thanks for replying.
    These are the switches i used for kiwi_nc:
    -s 192.168.10.19 -p 8073 -f 28122 -m usb -L100 -H2700 --ncomp
    Regarding the app from Chris: I need something I can run from a linux shell and it looks like his app runs on Win/MacOs only.
    thanks
    edited August 2022
    I used kiwi_nc successfully to stream IQ samples to dumphfdl while developing the Kiwi HFDL extension. Take a look at the "dumphfdl" target in kiwiclient/Makefile
    What you're doing looks okay to get a single channel (mono) without compression (IQ mode never has any compression, so --ncomp is not specified in the Makefile example)
    Note the argument to dumphfdl: --sample-format CS16 So kiwi_nc is outputting 16-bit signed integer values. The "C" means complex because of IQ, but that won't be true in your case.
    You might try redirecting the kiwi_nc output to a file. Then process it with sox into a .wav file. Something like this maybe:
    sox -r 12000 -b 16 -e signed-integer -c 1 -t raw CS16.raw -b 16 -e signed-integer -c 1 CS16.wav
    Where CS16.raw is the name of the file captured from kiwi_nc. Then play the .wav with a simple player (i.e. not Icecast) and see if it sounds right.
    Not 100% sure about the sox stuff. It's been a year or so since I did this.
  • Thank you for your help!
    After a thousand tries, I successfully made it run on the BB itself piping to
    lame -r -s 12 -V0 -m mono -p -x -b 16 --cbr --resample 22.050 --lowpass 4 - -
    and then to ezstream.
