Antenna switch extension with MS-S5 WiFi controlled switch
I have a strange issue with the antenna extension.
I have the Extension installed (from the JKS rep) and partly working, configured as ms-s4a-web. I shows the active antenna and will change the selected antenna two times but on the third selection it will jump a number.
My intention would be to switch sequentially, in the same way the web interface I.E. Antenna 1-2, 2-3, 3-4 etc. But there seems to be intermediate steps or overlapping instructions when using the extension.
Switching Antenna 1-2 becomes, 1-Ground-1-2
2-3 becomes 2-1-G-2-4, Missing 3 altogether.
I have noticed the ping times do seem very variable so I assumed it might be related to that, across two rooms it was between 215ms and 2ms, average about 40ms, moving the access point close to the switch I then got Minimum = 2ms, Maximum = 105ms, Average = 18ms which still seems quite a range.
As the low numbers will be a few in a row then a delayed response ~100ms and back to low numbers, I wondered how the UDP commands are timed and if they can respond to variations.
Any users of these devices (the ones that run under the ms-s4a-web instruction set) please let me know what I'm doing wrong.
I just have placed an order for one of these and will explore when it arrives in a month or two. If you make progress in the meantime, I'd be all ears!
Thanks
Look carefully at the
ant-switch-backend-ms-s4a-web scriptyou're trying to use with the ms-s5. You probably have to change the value of ANTENNAS from 4 to 5. Also note the very clumsy sequential stepping it does to select the desired antenna. This may be broken by the timing side-effects of using wifi. I don't know why the API is so bad. The ms-s7 was much better. See Ripperfox's comment here (he wrote the ms-s4a script): https://github.com/OH1KK/KiwiSDR-antenna-switch-extension/issues/34Getting back after quite some time. This does work, but slowly. I changed the antenna number to 5, and the ip address in the code. It takes about 4 secs to change. Using the direct control to the latency is more like a second.
Thanks so much for the work and the code.
