Reporting WSPR stations heard
Is the Kiwi able to automatically report any stations heard. If so I can't find instructions anywhere on how to set this up or anything in the admin mode that looks as if it is relevant.
P.S. How do I stop my local connection timing out so I can leave this running unattended?
Thanks
  • Sorry please ignore the above, I have finally found these options in the admin menus
  • If you're connecting from a browser on the same network as the Kiwi (e.g. 192.168.1.xxx) then you should be exempt from the timeout even if you have it setup on the admin "control" tab (inactivity time limit).
