gnu radio companion has been used for such but hardly a beginner's package
If you're talking about PACTOR, we had this discussion already: http://forum.kiwisdr.com/index.php?p=/discussion/2375/pactor-1-4
HF packet 300baud ax.25 (different then pactor) direwolf would be a example
ax.25 uses a 200 Hz shift @ 300 bps so I would think the existing FSK extension would decode the raw packets
AX.25 networking code is built into the Linux kernel. It's 26 years since I last used it!
Add Packet Digital Mode
http://forum.kiwisdr.com/index.php?p=/discussion/comment/12710#Comment_12710be a good bookmark to add to the plugin!
Is there a Program to do Packet using IQ Mode?
For Windows 10 and Linux?
GitHub - dl1ksv/gr-ax25: Some hamradio ax.25 routines for gnuradio
https://github.com/dl1ksv/gr-ax25you might also look at
http://uz7.ho.ua/packetradio.htm
