Filesystem is FULL on my KiwiSDR [fixed]
Installed version: v1.432, built Feb 11 2021 00:55:18
Cannot build, filesystem is FULL!
root@kiwisdr:/# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 0 10M 0% /dev
tmpfs 99M 8.3M 91M 9% /run
/dev/mmcblk1p1 3.5G 3.3G 24M 100% /
tmpfs 247M 0 247M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 247M 0 247M 0% /sys/fs/cgroup
root@kiwisdr:/# du -sh
/usr/bin/du: cannot access ‘proc/24692/task/24692/fd/3’: No such file or directory
/usr/bin/du: cannot access ‘proc/24692/task/24692/fdinfo/3’: No such file or directory
/usr/bin/du: cannot access ‘proc/24692/fd/3’: No such file or directory
/usr/bin/du: cannot access ‘proc/24692/fdinfo/3’: No such file or directory
0 dev
0 proc
0 sys
4.0K ID.txt
4.0K media
4.0K mnt
4.0K nfs-uEnv.txt
4.0K srv
16K lost+found
28K home
40K tmp
2.4M opt
3.3M etc
3.6M sbin
5.8M bin
8.3M run
21M boot
78M var
97M lib
852M usr
2.3G root
root@kiwisdr:/# cd root/
root@kiwisdr:~# du -sh
4.0K build.log
4.0K ovh-update.sh
92K extensions
596K KiwiSDR-antenna-switch-extension
26M kiwi.config
29M build
2.2G Beagle_SDR_GPS
root@kiwisdr:/usr# du -sh
4.0K games
4.0K src
3.4M sbin
39M bin
40M local
44M include
220M share
507M lib
There are no large log files. What can I do in this case? Any advice ?
2.2G Beagle_SDR_GPS
That's the problem. It should be < 250 MB at most. Use the alias
dufor a nice sorted list of file/dir sizes anddu.for the size of the current directory.So for example on one of my Kiwis:
root@www:~# cdp
root@www:~/Beagle_SDR_GPS# du.
237M .
0 d
0 g
0 kiwi
0 n
0 ng
4.0K config.h
4.0K dl
4.0K k
4.0K _LICENSE
4.0K other.config
4.0K RASPBERRYPI
4.0K types.h
4.0K up
4.0K update_fix
4.0K valgrind.h
8.0K bits.h
8.0K _COPYRIGHT
8.0K kiwi.h
8.0K Makefile.comp.inc
8.0K README.md
12K CROSS_COMPILE
12K kiwi.config
16K arch
16K main.cpp
44K Makefile
56K ui
100K init
104K CHANGE_LOG
104K net
160K e_cpu
292K support
328K pru
488K platform
544K verilog
652K gps
1.9M tools
2.1M KiwiSDR.rx14.wf0.bit
2.1M KiwiSDR.rx3.wf3.bit
2.1M KiwiSDR.rx4.wf4.bit
2.1M KiwiSDR.rx8.wf2.bit
3.9M verilog.Vivado.2017.4.ip
5.6M pkgs
5.7M rx
8.9M unix_env
9.3M web
16M extensions
This is strange.
du.- shows 2.2G., but sum of filesduapproximetly 100 MB.Maybe somewith wrong with files system ?
Try:
cdpcd .gitdu.laI'll bet for some reason you have huge files in the "hidden"
.gitdirectory. Although I don't understand why that would be.To recover from this you can simply remove the directory entirely, reclone and then rebuild. This should work even if you are connected via the admin page console tab because the system is running from the installed image and not from anything in ~/Beagle_SDR_GPS.
So try:
cd
rm -rf Beagle_SDR_GPS
df . [should be lots of free space now]
gclone Beagle_SDR_GPS
cdp
update_fix
When it finishes restart using the restart button on the admin control tab. Or if connected via ssh use the
kucommand.Thanks. Fixed.
