SWLJO43 My KiwiSDR and Problems only with AM, AMN and NBFM Mode
Hello,
however, if
Im receiving AM-Radio stations, I only can listen with USB-Mode. Whenever Im
switching from USB-Mode to AM or AMN, then the S-Meter goes from approximately
S2 to S9+10 and Im hearing the AM-Radio station very weakly, as if they are
being inhibited. L
Nearby,
only 10 km away, as the crow flies, is a local FM 10 Meter Repeater (DF0HHH).
Similar phenomena happen, whenever Im switching from USB-Mode to NBFM, then
the S-Meter goes from approximately S4 to S9+10 and I cant hear the repeater
at all. L
Ive tried
the following:
- Erasing the browser caches
(Edge, Chrome, Firefox) = no result - Restarting the beagle and the
KiwiSDR = no result - Ive inserted a resistor
between the antenna and the KiwiSDR to reduce the OV = no more red OV
indication - Ive shortened the Boni-Whip
Antenna from 10 cm to 1 cm = no result
Do you have
any Idea what Im doing wrong?
Dirk
(SWLJO43)
S-meter graph with -60 dBm = AM or AMN or NBFM (is the problem)
S-meter graph with -120 dBm = LSB or USB
https://forum.kiwisdr.com/uploads/Uploader/ef/b3d83ab633646ef896ad6372975d67.png
