I am not sure if GNURadio OOT (out-of-tree) modules do work on Windows unless they come already bundled with the binary Windows GNURadio installation.
Are there no binary boost versions for Windows?
I'd suggest to use Linux. It should not be too hard to run Ubuntu in a virtual machine on Windows in case you don't have a computer running Linux available.
If you do not need GNSS timestamps and RSSI values the you don't need the `kiwi_wav_source` block but can use the standard GNURadio wav source block.
The wav files produced by KiwiSDR are standard wav files, except when you use the option '--kiwi-wav', '-w'.
@Christoph I am trying to compile gr=kiwisdr. I understand that I must use the branch main-3.7 as I am running GNU Radio 3.7. How do I clone from it?
But when running: git clone --recurse-submodules https://github.com/hcab14/gr-kiwisdr.git cd gr-kiwisdr mkdir build cd build cmake ../ make install When running cmake../ I get the following error.. CMake Error at CMakeLists.txt:78 (find_package): Could not find a configuration file for package "Gnuradio" that is compatible with requested version "3.8".
The following configuration files were considered but not accepted: /usr/lib/x86_64-linux-gnu/cmake/gnuradio/GnuradioConfig.cmake, version: 3.7.11.0
Thanks for the help. I did get it working! (-: I am using Ubuntu 18.04 LTS and installed GNU Radio 3.7.11 from the Software Centre, which is latest version offered.
I found that running the following worked:
git clone --single-branch --branch maint-3.7 --recurse-submodules https://github.com/hcab14/gr-kiwisdr.git cd gr-kiwisdr mkdir build cd build cmake ../ sudo make install
Note: I had to use sudo 'make install' (a permission thing)
Now I can see kiwisdr listed right at the bottom of all the blocks in GNU Radio. kiwisdr align_streams coh_stream_syth kiwi_wav_source kiwisdr
Now to go and try get it all to work in GNU Radio. Hope this will help you @WAZ2ZKD and I am sure will be needing more help @Christoph
No, still only running GNU Radio 3.7.11 on Ubuntu 18.04. See attached image... Now I am struggling to set up the Correlation Estimator Block. Not used that block before. And also do not know how to connect the kiwisdr block to my Kiwisdr whose IP address is 192.168.8.120 on my LAN.
Hi @Christoph, could you please give me you settings for ipz in the Correlation Estimator above? With the settings I have in the kiwisdr block, should it connect to my kiwisdr on my LAN? Thanks.
But when running:
cd gr-kiwisdr
mkdir build
cd build
cmake ../
make install
How do I solve this please..
you have gnuradio-3.7 installed, so you need to use the maint-3.7 branch, i.e.,
git checkout maint-3.7I am using Ubuntu 18.04 LTS and installed GNU Radio 3.7.11 from the Software Centre, which is latest version offered.
cd gr-kiwisdr
mkdir build
cd build
cmake ../
sudo make install
kiwisdr
align_streams
coh_stream_syth
kiwi_wav_source
kiwisdr
Thanks.
