v1.391,392,393,394: New noise blanker and filters
                    From the CHANGE_LOG file:
                            v1.391  May 23, 2020
    User interface changes:
        SAL, SAU mode passband image will only show single sideband (just like LSB, USB).
        Ctrl/alt-click on mode button toggles modes backwards (most useful with SAM modes).
        Same works with keyboard shortcuts, e.g. ctrl/alt-A toggles SAM modes backwards.
    Noise blankers and filters:
        Reworked the audio tab user interface to support multiple blanker/filter algorithms.
        New algorithms planned but not yet available are greyed-out in the menus.
        From Warren Pratt's wdsp package added the variable-leak LMS algorithm.
    Merged Howard Su's RPi changes.
        Note: RPi is not officially supported by KiwiSDR. Ask for help on the KiwiSDR forum:
            http://forum.kiwisdr.com/discussion/1986/port-kiwisdr-to-raspberrypi-3b
    Bug fixes:
        Audio recordings made in SAS (synchronous AM stereo) mode now work.
        Fixed problem with ITU region 2 Kiwis and shift-clicking waterfall in 75/80m band segment.
        from lazywalker: fixed problems with frequency memory and reload value when transverter offset used.
Note that some noise filters always require their sections be enabled via the "more" panel. Otherwise simply selecting their menu entry does nothing. In particular the wdsp and LMS filters since they have independent denoiser and autonotch sections that are enabled separately (or both simultaneously).
Just been listening to some interesting other viewpoints to the uniform UK MSM.
I'd forgotten one of the pleasures of SWL.
