Seeed KiwiSDR metal enclosure finally available!
Shipping December 15 it appears: https://www.seeedstudio.com/KiwiSDR-Enclosure-p-3012.html
https://forum.kiwisdr.com/uploads/Uploader/73/ff5090c809dc95d29179a534693936.jpg
Preview the assembly instructions here: http://www.kiwisdr.com/files/enclosure.jpg
Looks fine, are they EMC tested?
Thinking about shielding the VHF (145MHz) spurs
Regards
OZ1AEF
Bjarne
Anyway very nice enclosure.
https://forum.kiwisdr.com/uploads/Uploader/40/66aedc5da494fe316792ec3c2a81b3.png
https://forum.kiwisdr.com/uploads/Uploader/ef/c32bf2650ad9f650aa1bdfe184ca8c.png
Seeedstudio KiwiSDR Enclosure
Hi. I found that KiwiSDR in such metal case emits interference at frequencies above 65 MHz. The culprit of the interference is the LMR10530Y pulse converter. But the main problem is that the SMA connector thread does not have physical contact with the metal case. I replaced the end plate and there was much less interference. You can probably use the original end plate and large washers and nuts to ensure contact between the SMA connector and the main metal case.
Short video:
https://youtube.com/shorts/2ooQANhmqos
My KiWi metal case modifications were illustrated in this previous thread.
https://forum.kiwisdr.com/index.php?p=/discussion/comment/7539Regards,
Martin, thanks! Very interesting article!
I suggest being a bit cautious about simply grounding the SMA's, HF antenna and GPS, to the enclosure. In so doing you are creating another shunt path for common mode current through the entire structure, That is, for example, current coming in on the LAN going throught the Kiwi's ground plane and back out the PS.
Whether the overall result is better than leaving the path out the SMA common choked may depend upon the characteristics of the injected current and the resulting path.
In the past I've made PCB end plates to replace the stock ones, some having GPS chokes, some flux-coupled transformers and some shorted. I didn't find a clear winner for all situations.
In addition to KiwiSDR, I have several other receivers with remote access. And these receivers work on VHF. The installation of this end plate with a physical SMA contact on the shield completely freed the VHF receivers from interference. And by the way, these common-mode currents (in which I don't understand anything) most likely explain the absence of these interferences on HF.
Hi Glen,
If you take a look at the spectrum analyser plots in the previous thread I linked to, you will see that even with the standard metal case, there is a significant amount of radiated noise at <150MHz , 450MHz, 750MHz & 1.5GHz.
My concern was also that the KiWi was on a remote site with other VHF / UHF receivers and I wanted to avoid causing interference to them. Connecting the SMA connectors to the case made a significant difference in this respect. However I appreciate that doing this may also cause other problems with the KiWi and reception <30MHz, such as the common mode issues you have mentioned.
You are definitely correct in saying that there is no clear winner, and I have found something that helps at one site often makes things worse at another. Experimentation is nearly always required to determine the best compromise.
The only sure fire thing is that adding any type of metal case as a first step, rather than just using the supplied plastic plates and metal sides, is likely to significantly reduce the level of radiated emissions.
To be honest I don't know how many of the manufacturers of single board computers get away with the level of emissions their products produce. If they were a domestic item they would not pass the various EMC standards that would be required to allow them to be sold commercially. I can only assume that because they are a partial assembly or kit, that is intended to be used in something else, this provides a loophole for exemption. Or maybe they just don't care...
I am looking for a metal case for my Kiwi1, it seems impossible to find now.
If you have any idea where I can buy one, it would be nice.
73's de J-Luc F1JEK
