Good DRM decodes on 15109.70 KHz
Hi All,
Today I finally managed to get every good DRM decodes (no dropouts) using both Dream and Sodira from Radio Kuwait on 15109.70KHz (yes it does seem to be slightly off-frequency).
The trick with Sodira seem to be to use the 'Simple' mode and select DRM30. Once you obtain lock you can then select 'DRM' and it remains locked. If I tried 'DRM' from cold it wouldn't lock at all.
