Endless update loop?
Hi.
Just got our first KiwiSDR, tried to get it to work.
After first power the LEDs continue to blink, the webpage says "Sorry, software update in progress. Please check back in a few minutes.
Or check sdr.hu for more KiwiSDR receivers available world-wide. Build: compiling file #30"The number of the file varies.
After waiting more than 30 minutes I logged in via ssh and checked the log. It repeats the below cycle every three minutes. To me that looks like the device is stuck in an update loop.
Please advise if I am just impatient or what
This has been running now for more than one hour...
Please let me know if you need additional information...
Ekki, DF4OR
# journalctl -f
Nov 21 22:11:31 kiwisdr kiwid[5274]: DEBIAN 8
Nov 21 22:11:31 kiwisdr kiwid[5274]: USE_SPIDEV
Nov 21 22:11:31 kiwisdr kiwid[5274]: LOAD_SPI = no
Nov 21 22:11:31 kiwisdr kiwid[5274]: Stopping kiwid:
Nov 21 22:12:01 kiwisdr kiwid[5280]: DEBIAN 8
Nov 21 22:12:01 kiwisdr kiwid[5280]: USE_SPIDEV
Nov 21 22:12:01 kiwisdr kiwid[5280]: LOAD_SPI = no
Nov 21 22:12:01 kiwisdr kiwid[5280]: Starting kiwid
Nov 21 22:12:01 kiwisdr kiwid[5280]: Start kiwid: OK
Nov 21 22:12:01 kiwisdr kiwid[5280]: Mon Nov 21 22:12:01 UTC 2016
Nov 21 22:12:01 kiwisdr kiwid[5286]: 0:00:00 .... KiwiSDR v1.2 --------------------------------------------------------------------
Nov 21 22:12:01 kiwisdr kiwid[5286]: 0:00:00 .... compiled: Aug 10 2016 21:09:53
Nov 21 22:12:01 kiwisdr kiwid[5286]: 0:00:00 .... reading configuration from file /root/kiwi.config/kiwi.json
Nov 21 22:12:02 kiwisdr kiwid[5286]: 0:00:01 .... serial number from EEPROM: 1078
Nov 21 22:12:02 kiwisdr kiwid[5286]: 0:00:01 .... reading configuration from file /root/kiwi.config/dx.json
Nov 21 22:12:02 kiwisdr kiwid[5286]: 0:00:01 .... 883 dx entries
Nov 21 22:12:02 kiwisdr kiwid[5286]: 0:00:01 .... listening on port 8073 for "openwebrx"
Nov 21 22:12:02 kiwisdr kiwid[5286]: 0:00:01 .... webserver for "openwebrx" on port 8073
Nov 21 22:12:02 kiwisdr kiwid[5286]: 0:00:01 .... ### using SPI_DEV
Nov 21 22:12:03 kiwisdr kiwid[5286]: 0:00:02 .... FPGA version 1
Nov 21 22:12:03 kiwisdr kiwid[5286]: 0:00:02 .... CFG read /root/kiwi.config/kiwi.json: sdr_hu_register = false
Nov 21 22:12:06 kiwisdr kiwid[5286]: 0:00:05 .... (0 users)
Nov 21 22:12:06 kiwisdr kiwid[5286]: 0:00:05 .... UPDATE: scheduled
Nov 21 22:12:06 kiwisdr kiwid[5286]: 0:00:05 .... UPDATE: checking for updates
Nov 21 22:12:06 kiwisdr kiwid[5286]: 0:00:05 .... UPDATE: version changed, current 1.2, new 1.24
Nov 21 22:12:06 kiwisdr kiwid[5286]: 0:00:05 .... UPDATE: building new version..
Nov 21 22:12:08 kiwisdr kiwid[5286]: 0:00:07 .... DDNS: private ip 192.168.5.219/24
Nov 21 22:12:08 kiwisdr kiwid[5286]: 0:00:07 .... DDNS: public ip [censored]
Nov 21 22:15:13 kiwisdr kiwid[5286]: 0:03:12 .... UPDATE: switching to new version 1.24
Nov 21 22:15:15 kiwisdr kiwid[6215]: DEBIAN 8
Nov 21 22:15:15 kiwisdr kiwid[6215]: USE_SPIDEV
Nov 21 22:15:15 kiwisdr kiwid[6215]: LOAD_SPI = no
Nov 21 22:15:15 kiwisdr kiwid[6215]: Stopping kiwid:
Nov 21 22:15:45 kiwisdr kiwid[6221]: DEBIAN 8
Nov 21 22:15:45 kiwisdr kiwid[6221]: USE_SPIDEV
Nov 21 22:15:45 kiwisdr kiwid[6221]: LOAD_SPI = no
Nov 21 22:15:45 kiwisdr kiwid[6221]: Starting kiwid
Nov 21 22:15:45 kiwisdr kiwid[6221]: Start kiwid: OK
Nov 21 22:15:45 kiwisdr kiwid[6221]: Mon Nov 21 22:15:45 UTC 2016
Nov 21 22:15:45 kiwisdr kiwid[6227]: 0:00:00 .... KiwiSDR v1.2 --------------------------------------------------------------------
Nov 21 22:15:45 kiwisdr kiwid[6227]: 0:00:00 .... compiled: Aug 10 2016 21:09:53
Nov 21 22:15:45 kiwisdr kiwid[6227]: 0:00:00 .... reading configuration from file /root/kiwi.config/kiwi.json
Nov 21 22:15:45 kiwisdr kiwid[6227]: 0:00:00 .... serial number from EEPROM: 1078
Nov 21 22:15:46 kiwisdr kiwid[6227]: 0:00:01 .... reading configuration from file /root/kiwi.config/dx.json
Nov 21 22:15:46 kiwisdr kiwid[6227]: 0:00:01 .... 883 dx entries
Nov 21 22:15:46 kiwisdr kiwid[6227]: 0:00:01 .... listening on port 8073 for "openwebrx"
Nov 21 22:15:46 kiwisdr kiwid[6227]: 0:00:01 .... webserver for "openwebrx" on port 8073
Nov 21 22:15:46 kiwisdr kiwid[6227]: 0:00:01 .... ### using SPI_DEV
Nov 21 22:15:47 kiwisdr kiwid[6227]: 0:00:02 .... FPGA version 1
Nov 21 22:15:47 kiwisdr kiwid[6227]: 0:00:02 .... CFG read /root/kiwi.config/kiwi.json: sdr_hu_register = false
Nov 21 22:15:49 kiwisdr kiwid[6227]: 0:00:04 .... (0 users)
Nov 21 22:15:49 kiwisdr kiwid[6227]: 0:00:04 .... UPDATE: scheduled
Nov 21 22:15:50 kiwisdr kiwid[6227]: 0:00:05 .... UPDATE: checking for updates
Nov 21 22:15:50 kiwisdr kiwid[6227]: 0:00:05 .... UPDATE: version changed, current 1.2, new 1.24
Nov 21 22:15:50 kiwisdr kiwid[6227]: 0:00:05 .... UPDATE: building new version..
Nov 21 22:15:52 kiwisdr kiwid[6227]: 0:00:07 .... DDNS: private ip 192.168.5.219/24
Nov 21 22:15:52 kiwisdr kiwid[6227]: 0:00:07 .... DDNS: public ip [censored]
thanks for the fast reply. I wanted to test your procedure this morning and now it upgrades smoothly to new version 1.25.
So I will not go through the manual procedure you suggested, I assume that you fixed something over night
I will check some more of the batch of KiwiSDR which arrived yesterday and see if they upgrade all ok.
Ekki, DF4OR
