MW Band Attenuation to improve S/N up and down band
                    I'm looking for an inexpensive filter to attenuate across the MW AM Broadcast band without blocking out the LW and lower frequencies. I have success in improving the S/N ration and eliminating what appear to be AM Broadcast station spurs up the frequency by using a 2 pole Chebyshev Hi-pass filter that starts attenuating below 1800 Hz. The attenuation curve is substantial starting at 1 KHz and completely eliminates most stations below 500 KHz. The first 2 attached images show the attenuation characteristics first with filter, then without. The 2nd 2 attached images attempt to show the difference in S/N ratio between the filter and without the filter. The first image being with filter and the second being without filter. I do not have experience with filter circuits that would achieve this result without using switches. Generally, I want to reduce the AM Broadcast MW band by about 15 dB and not affect the LW band or the frequencies above 1800 Hz.
https://forum.kiwisdr.com/uploads/Uploader/88/2ee564fcf83e382a0feb6aa58b9b2c.png
https://forum.kiwisdr.com/uploads/Uploader/05/caf606650da8e9cdead28ba35e1e1b.png
https://forum.kiwisdr.com/uploads/Uploader/3e/7aad4188b1387ac11815b253663a73.png
https://forum.kiwisdr.com/uploads/Uploader/98/396d416af682dd80a2ecb5ccb876f5.png
                            Ron - KA7U
