v1.822
From the CHANGE_LOG file:
v1.822 September 28, 2025
  Antenna switch:
    Use the "\+" escape sequence where you need a plus sign ('+') to appear in the curl fields.
    Example "192.168.1.222?cmd=ant+1\+2+on" gives "192.168.1.222?cmd=ant 1+2 on"
Note that '+' alone gives a single space as before. (thanks IW2NKE)
    Debugging mode added to ant-switch-frontend script. Preface any command with 'd' to enable.
    E.g. "d s" to query switch status with curl debugging ("--verbose") enabled. Also sets
    script "DEBUG" variable which individual scripts can use to trigger debugging actions.
    The "ad" alias helps with this e.g. "ad s" instead of "./ant-switch-frontend d s"
  SSTV extension: Works on 3-channel mode Kiwi again. (thanks nitroengine)
  The server will now run and allow you to connect as admin even if the Kiwi board is broken
    (e.g. FPGA not responding) or not installed. The FPGA communication failure LED pattern is
    then appended to the IP address LED pattern in this case (see: kiwisdr.com/info/#id-fpga)
studentkranitroengineiw2nkeIK8SUTjimjackiiG4ZFE
