v1.817
From the CHANGE_LOG file:
v1.816,817 August 7, 2025
  Better indication of when a channel is initially occupied. (thanks AC8FL)
    The list of connections displayed on the control panel "User" tab and admin "Status" tab
    is updated every 3 seconds. But a "bot" connection that isn't following the Kiwi API rules
    takes about 10 seconds to be correctly identified and kicked. This has the side-effect of
    making a channel look available when in fact it is occupied for those 10 seconds
    (because the connection list entry is still blank). If this happens to the last channel
    available you might incorrectly get the impression the channel isn't being “released"
    because it looks unoccupied, but you can't connect to it (all channels are seen as full).
    To make this situation more clear a user name of "(connecting)" will be shown immediately
    when a channel is first allocated and updated when the connection is fully established.
    This will also make it somewhat easier to spot when there are lots of bot connection
    attempts rather than having to spot them by reviewing the log.
  Admin webpage tab:
    New button "Display all fonts in bold" which some of us need, lol. (thanks Jerry and KFS)
      Does not apply to the admin page currently. This change required minor adjustments to
      the user interface nearly everywhere to account for the larger size of the bold fonts.
      If you see a spot where things look wrong please let us know.
F5AFYHB9TMCnitroengineG4ZFE
