v1.811
From the CHANGE_LOG file:
v1.811 May 29, 2025
Web server:
Return connection error until local IP known so local-IP exemption works. (thanks Palomar)
Don't send Content-Length header since chunked encoding used. (thanks G7GSF)
Don't apply admin shortcut keys when control/option/meta modifier keys used. (thanks F5LFE)
SNR measurement now works even if admin control tab "disable waterfalls" is set. (thanks VA3ROM)
When antennas are switched an auto aperture measurement is made, if enabled. (thanks jimjackii)
Does your Kiwi use a USB WiFi dongle and not have anything connected to the Ethernet port?
If so, I'd like to know as soon as possible if the v1.811 release works with your Kiwi or not. Thanks!
It seems DRM is broken in this release. I don't understand how.
Another problem: Returning the 503 error causes direct-to-computer/laptop Ethernet connections to fail. This is because we've apparently had a bug for many years in the local IP detection code.
This bug didn't prevent direct-to-computer connections in years past. But it does cause the new 503 error to be returned indefinitely now preventing connections. But ONLY for computers/laptops where IPv6 link-local addresses are assigned for the direct connection, instead of the more common IPv4 169.254.xxx.xxx link-local addresses.
Bugger. I like tuning into DRM from time to time. It's a reassuring sign my antenna is working well! :-)
I've found the problem. I'm trying to get a release together as soon as I can. But it's much more difficult these days.
Appreciate your efforts! No stress here.
Thanks John for your tireless efforts, they are greatly appreciated !
Notice DRM is showing under 3dB signal to noise ratio in DRM box despite got around 20dB above noise on spectrum display
Thank you, John.
the automatic adjustment of the waterfall after antenna switching works very well.
Regards, Steffen (jimjackii)
