v1.805
From the CHANGE_LOG file:
v1.805 March 9, 2025
Mobile improvements:
Keyboards shortcuts work again, e.g. a Bluetooth keyboard connected to iPad. (thanks DL3LED)
Popup keyboard dismissed properly after "return" key pressed (e.g. on "ident" fields)
Disabled input field auto complete, auto correct, auto capitalize.
Antenna switch:
Buttons now turn green for Kmtronic-2ch switch. (thanks Fernando)
Multiuser/mixing denial notification working again. (Thanks Steffen)
CW Skimmer extension: New. But consider it experimental as there are a number of problems.
SSTV extension: Fixed MP mode height issue. (thanks VK3HK, VK3KHZ)
DX label filter panel: Reset button now clears ident & notes fields.
Update to satellite table to reflect recent Galileo changes. (thanks F4FPR)
SSTV MODE! :D Wow! Color me "Tickled Pink"! This is a very pleasant surprise!
One small glitch just happened, with a Robot12 BW signal. The picture came through perfectly, but the display didn't stop when the signal stopped... it scrolled several lines of noise, and then stopped. I can't seem to find the original image, which scrolled "out of the top".
Another image came in a few mins later, "M1" in perfect color & quality, and that worked fine.
This is so cool! :) AND, I just noticed that Oona wrote this! She is very talented!
A small issue: If a signal is caught in mid-stream, nothing happens. If the initial FSK ID is missed, the decoder never starts. Still, it is nice to have SSTV "built in". :)
Thanks for mentioning the R12-BW problem. I've fixed it now (and a few others) for the next release.
It's not so much the FSK ID being missed as the VIS code which is required to setup all the timing parameters needed for decoding.
dang - not a lot of SSTV in this part of the world. (NZ)
