v1.804
From the CHANGE_LOG file:
v1.804 February 21, 2025
Antenna switch:
Fixed curl command processing. Use a plus sign ("+") to indicate a space in your curl URL.
E.g. "http://192.168.1.2?cmd=ant+1" runs curl with a URL argument of
"http://192.168.1.2?cmd=ant 1". A space is used as before to separate the arguments for
multiple commands. E.g. "http://192.168.1.2?cmd=ant+1 http://192.168.1.3?tune=144MHz".
(thanks Steffen)
Added a field for specifying a curl command to run when the antenna is switched to ground
(because the "Ground antennas when no users connected" option is enabled).
Added backend for Kmtronic 2-channel device [but needs testing]. (thanks Fernando)
TDoA:
Added URL parameter to populate sampling station list with custom/private entries
(i.e. sampling hosts that are not on the map). See TDoA help panel.
Fixed admin backup tab function broken by the admin password reset change.
Disabling user connections (admin control tab) now also stops autoruns.
Thank you for the changes.
The cURL commands with "+" work.
It also switches to the default antenna, but not when no users are connected, but only when the first user connects to the Kiwi.
Would it be possible to hide the "RF attn" part of Kiwi 1?
Regards, Steffen
