FT8 decoding Frequency: 0.000 MHz (invalid) Using: N1DQ-Importer-KA9Q-Radio
sometimes this happens :
Monitor: F4VTQ Loc JN28UX
Antenna: No antenna information
Show transmitter distance chart
Last report: YO6LM
at Mon, 09 Dec 2024 09:08:30 GMT
Is that a known issue coming from the internal KIWI-SDR FT8 decoder ? Or should I look somewhere else ?
Thanks
    edited December 2024
    What's confusing me is that KA9Q-Radio is mentioned (RX-888 software mostly). Some Googling shows this issue is mentioned elsewhere, but without any indication of the true source.
    This is not Kiwi-related that I'm aware of.
  • edited December 2024
    The version info on PSKreporter can be misleading.
    I'm uploading with 3 different versions, and it's always mixing those up. The version info in the spot does very often not coincide with the software which it was actually uploaded with.
    But as far as I know, wsprdaemon is using KA9Q-radio for FT8, so that might be at least where the version info came from.
  • In that case I would suggest starting here: https://groups.io/g/wsprdaemon/topics
  • Erwin, I see you had already posted the question there. So let's see what they say.
