SWBC Database lookup
G'Day all,
Anyone having problems with the SWBC database lookup, seems the webpage is not getting the correct frequency from KIWISDR.
Cheers Steve
  • seem OK here
  • Same here, no such problem.
    edited November 2024
    It appears that, in Firefox only, if you try and open www.short-wave.info instead of http://www.short-wave.info (note explicit http:// prefix) Firefox goes into a redirect loop. But Safari and Chrome worked fine for me in that case.
    Guess I need to change the Kiwi code to force http://
    VK4018SWL
  • Tried all browsers and they do the same. Still not sure why. But it is a minor problem. Thanks for the replies.
    Steve
  • It appears that, in Firefox only, if you try and open www.short-wave.info instead of http://www.short-wave.info (note explicit http:// prefix) Firefox goes into a redirect loop.
    I can't confirm that. Firefox is my standard browser, but I never experienced such problem. Maybe my configuration is different. When hovering over both links, the status line shows the same target in both cases - always without prefix. And identical behavior on clicking - no redirection loop in each case. For me, it seems like FF adds http:// internally if missing (just as one would expect).
  • Problem solved, me being a dummy, I was clicking on the far left near database: stored instead of clicking on the frequency that I wanted know about. Thanks to all for replying to the post.
    Steve
