v1.704 update
So I released v1.704 today. But with only a couple of exceptions it failed to install anywhere. And I don't understand why. All of my testing installed fine. Not even Kiwis still building from source code updated properly.
I need admin access to someone's Kiwi where there is a failed install error message in the Kiwi log or the build.log file. Please email to support@kiwisdr.com. Thanks
Both of mine are locked up.
Update tab shows updating to 1.704.
#2 finally started working.
#1 indicates updating to 1.704 when I click on "Check for Updates"
I emailed Admin info.
Thanks for everything.
Rich
Follow up for my #1 Kiwi - http://k9dxikiwi.proxy.kiwisdr.com:8073/
Be aware that it is configured to auto forward to my #2 kiwi.
From the Admin page Log - It appears to be restarting every 5 minutes. SNR 0/0. Check for Updates indicates it is updating to 1.704 from 1.703.
Admin info emailed to you.
After watching it reboot every 5 minutes for several hours, I tried something.
On the update tab I clicked on 3 things - Automatically check for updates? NO, Automatically install updates? NO, Disable recent changes? Yes
The kiwi restarted and is functioning normal on 1.703
Still running v1.702, clicked "check now" and it showed "Git clone damaged!".
I closed the Admin interface, reopened it a little while later and clicked "Check now" again and now it displays "Available version v1.704".
I have not attempted to force a build yet. The Kiwi is currently running as normal. I have a backup from several versions back I can restore it with if needed.
I just had a ~30 second power outage several minutes ago. After the Kiwi restarted (it never displayed an update screen), it's now showing it's on v1.703. I never forced a build. Showing "Git clone damaged!" when "Check now" is clicked.
Repeating what I did above, exiting out of the Admin interface and coming back and clicking "Check now" again, it now displays "Available version: v1.705".
I have not yet attempted to force a build. As far as I can tell, the Kiwi is still working as normal.
This is a KiwiSDR 1 still running Debian 8.5. I plan to update it to Debian 11 sometime this winter.
See the recent announced post for a solution to this problem.
