kiwirecorder, net cat mode
adding -nc when kiwirecorder is invoked causes it to stream to stdout and it can be piped to a decoder. Am I correct that only the raw stream is sent, no headers or anything else?
As far as I know there shouldn't be any headers (e.g. WAV file). I just copied the code from kiwi_nc.py the best I could. So if that's working then -nc with kiwirecorder should work as well. I could only do minimal testing though.
In the latest kiwiclient/kiwirecorder update the
--progress
option can now be used with--nc
/--netcat
. It will print the progress information to stderr instead of stdout so it doesn't mix with the streamed data (given that you're typically redirecting or pipelining stdout somewhere).
