KiWi antenna switch using KMTronic UDP switch protocol as emulated by KiWi
Can anyone tell me what the format is of the switch reply to the KiWi in order for the switch number to go green? I'm seeing wireshark port unreachable packet rejects from KiWi when producing a response on either the defined port in the admin setup, or the default 12345. Also what is the syntax of the response to FF0000, which I assume is ascii 10000000 etc. but I can't confirm it as the packets are rejected. Thanks.
