Antenna Switch UDP control with Aziloop
I'm working on a feature request from several Aziloop and KiWi users to allow antenna headings to be set from the KiWi app as if they are different KiWi antenna switch options, and as I use UDP already that's the best option.
Am I right in assuming that KMTronic UDP is the only UDP option in the list?
I've seen some discussion about antenna switch operation. What UDP response/ACK does KiWi need back to turn a switch button green?
Thanks
Dave GW4GTE
