Channel password problem
I have two Kiwi's SDR's remotely running v 1.591 via Cloudflare tunnel, on Debian 10 Buster and (BBG). When I try to restrict the "Number of channels not requiring a password even if password set" this doesn't work, except if I choose "None" Then all channels require a password. I have tried with 1 to 7 options, and all failed. This happens on both Kiwi's. Do any others have the same issue?
I should also mention that the second Kiwis was upgraded to debian 10 using the backup sd card of the first one. So they are 100% identical software wise.
Sincerely Levi P. Iversen, Norway
Found out that this issue also has to do with using cloudflare tunnel as "reverse proxy server", as with the problem with time limit and activity limits.
Lpi
