A masked band segment .. problem ??
Earlier I tried using type label "masked" in DX settings and found it was weird that
The masked band was VALID for my local connection (192.168.1.127:8073) as shown below
The masked band was INVALID for outward connection (jjm0311.ddns.net:8073) as shown below
Was that normal ??
Did I miss something with DX setting label or just a bug needs to be fixed later?
( FYI: my Kiwi ver.=1.578, Freq=1750khz, Mode=AM, Passband=83000Hz,Type=masked )
Thank for your feedback and opinion in advance.
B/R,
Jimmy
I can't confirm that. If I visit your kiwi, I see the area around 1.75 MHz masked as intended.
Maybe try flushing your browser cache ?
Hi Martin, you are correct.
The browser that I have ever used with admin to visit would ignore the masked function.
This case can be closed.
Then, the remaining question for me is whether the masked audio was truly sent to the receiving end or not. Certainly the former should be pretty much easier.
