v1.555: improvements to build process
From the CHANGE_LOG file:
v1.555 Aug 25, 2022
Improvements to build process:
Better error messages when admin update tab "check now" or "build now" fails.
Similarly, better error messages in log file.
Console tab, new button "re-clone Beagle_SDR_GPS".
If the build returns the error message "Git clone damaged!" use this button to recover.
The latest Kiwi software will be re-cloned from github.com
Understand consequences before using:
1. The Kiwi configuration information in /root/kiwi.config will NOT be changed.
2. The Kiwi git clone (source files) in /root/Beagle_SDR_GPS will be completely removed
and re-cloned. In the unlikely event you have made custom changes they will be lost.
You must restart after the re-clone and let a full build occur.
iframe extension now accepts arbitrary HTML/Javascript in addition to existing URL parameter.
Examples (see admin extensions tab, iframe entry)
URL:
https://services.swpc.noaa.gov/images/planetary-k-index.gif
HTML:
<center>
<a href="https://www.hamqsl.com/solar.html"
title="Click to add Solar-Terrestrial Data to your website!">
<img src="https://www.hamqsl.com/solarbrief.php">
</a>
</center>
BBAI-64: Expand main memory available from 2 GB to 4 GB.
