sig_gen extension
Hi John,
I'm trying to perform some receive system fault finding, and I'd like to understand how the sig_gen extension works a bit better.
Where exactly does it inject the signal into the Kiwi ?
Is it an actual RF signal injected into the antenna port before the LPF, or is it a bit further down the chain ?
Does it actually make use of the ADC, or is it routed internally in the FGPA simulating an ADC output and therefore entirely bypassing the whole ADC stage ?
No need for a detailed reply, just a quick answer would be fine. I'm just trying to understand the basics.
  • It's all digital inside the FPGA. It's just a DDS that gets switched in place of the ADC input.
  • Hi John,
    OK thanks for that.
    Just to clarify, if the ADC was faulty, the internal signal generator would still give the correct levels ?
  • Yes. The ADC XO (separate part from ADC itself) has to be working. But otherwise bad outputs from the ADC itself shouldn't affect things when in sig gen mode.
  • As I understand it, sig-gen is an FPGA software tool. What if we try to use a free GPIO and generate a hardware PWM signal to test the ADC?
  • Yes. That's a very good idea and has not gone unnoticed..
  • edited July 2023
    Thanks, John. We always ready to give you new ideas. And I really hope that you will be able to implement them.
