lsb mode not working with kiwirecorder
I am trying to record one or more 40 meter LSB stations with the kiwirecorder, but it's not working. I can record the other modes fine, but not lsb. Thanks in advance for any help.
Jon
  • edited May 2022
    Here's the script I use. For recmode, anything other than lsb records correctly.
    #!/usr/bin/env bash
    ctrl_c() { kill %%; exit; }
    set -u   # Show usage of unset variables as an error to help catch typos
    #common to all
    kiwirec=~/kiwiclient/kiwirecorder.py
    kiwi_port=8073
    DL=~/Desktop/Jon_tests
    rec1freq=7255
    recmode=lsb
    min=1
    c_min=1
    kiwi_IP1=mauisdr.wsprdaemon.org
    ID1=rec1
    echo Armed, ctl-C to quit
    min=$(date +%M)
       c_min=$min
       while [ $c_min -eq $min ] ; do
         sleep 1s
         c_min=$(date +%M)
       done
    trap ctrl_c INT
    for (( ; ; ))
    do
    min=$(date +%M)
    if [ $min -eq 54 ] ;then
      echo Recording, ctl-C to quit
         $kiwirec -s $kiwi_IP1 -p $kiwi_port -f $rec1freq -m $recmode --tlimit=60 -d $DL --station=$ID1
     fi
    echo ""
    c_min=$min
         sleep 1s
         c_min=$(date +%M)
       done
    done
  • Worked fine when I tried it. Make sure you have the most recent version installed. Add to the command options --log-level=debug and make sure an lsb passband is being sent to the Kiwi. In the log output below this is the low_cut=-2700 high_cut=-300 part in addition to mod=lsb
    2022-05-27 07:20:00,008 pid 98391 send SET (SND) "SET AR OK in=12000 out=44100"
    2022-05-27 07:20:00,008 pid 98391 recv MSG (SND) sample_rate: 12001.097068
    2022-05-27 07:20:00,008 pid 98391 send SET (SND) "SET squelch=0 max=0"
    2022-05-27 07:20:00,008 pid 98391 send SET (SND) "SET genattn=0"
    2022-05-27 07:20:00,008 pid 98391 send SET (SND) "SET gen=0 mix=-1"
    2022-05-27 07:20:00,009 pid 98391 send SET (SND) "SET ident_user=kiwirecorder.py"
    2022-05-27 07:20:00,009 pid 98391 set_mod: IQ_or_DRM_or_stereo=0 num_channels=1
    2022-05-27 07:20:00,009 pid 98391 send SET (SND) "SET mod=lsb low_cut=-2700 high_cut=-300 freq=7200.000"
    2022-05-27 07:20:00,009 pid 98391 set_agc: on=True hang=False thresh=-100 slope=6 decay=1000 gain=50
    2022-05-27 07:20:00,009 pid 98391 send SET (SND) "SET agc=1 hang=0 thresh=-100 slope=6 decay=1000 manGain=50"
    2022-05-27 07:20:00,837 pid 98391 recv MSG (SND) max_thr: 90
