Kiwirecorder
Is Kiwirecorder available ported for Windows? If not what would be a good audio recording utility to use with Windows?
Just install python on your Windows box and you should be on your way. That install is pretty much plug and play
after installing python get into a command line prompt and use the command pip install numpy
I just did that fresh on a W10 box and it all seems to work
here's what you need for W10
