KiwiSDR app for Android
The KiwiSDR app for Android devices provides access to the known Wideband Shortwave Radio Reciever Map (map.kiwisdr.com), which locates worldwide sites of KiwiSDR shortwave receivers covering the spectrum of 1 - 30 MHz.
App functions:
→ Hit a marker symbol to display a link to the chosen KiwiSDR receiver.
→ Follow the links to open the corresponding receiver view.
→ On the receiver view, tap the back button of your device to get back to the initial KiwiSDR map at any time.
→ On the map view, tap the back button to display a help & exit dialog.
The KiwiSDR app may be obtained from https://play.google.com/store/apps/details?id=appinventor.ai_bernd_hebel.KiwiSDR
Please find an earlier conversation about the KiwiSDR Android App here:
http://forum.kiwisdr.com/index.php?p=/discussion/comment/11916#Comment_11916
when trying to download app i get
We're sorry, the requested URL was not found on this server.
I think it was finally removed from the Android app store.
But I saved a copy at: kiwisdr.com/files/gavtrok.apk (or possibly KiwiSDR2.apk -- there are two .apk files and I can't remember what they are and my notes don't have any info about them)
There is also likely the issue of how you install/run a .apk on Android outside of the store. That's maybe seen as a security issue and blocked. But I know nothing of the Android environment.
https://forum.kiwisdr.com/index.php?p=/discussion/comment/20575#Comment_20575Johnf, you can still download the last version from apkpure https://apkpure.com/kiwisdr/appinventor.ai_bernd_hebel.KiwiSDR
You will have to "allow apps from unrecognised sources".
How you do that varies from Android version and different manufacturers, but is usually under Settings > Apps >.
