BBAI Cannot connect via web browser after build - A little help needed
2»
  • Guys, how do I make it so my CPU speed is set to 1.18Ghz permanently so that when it reboots it does not revert to 1.5Ghz? Do I need to nano a file somewhere? I want to set the cpu speed that bit slower whilst I'm sorting out the cooling.
  • .......... and also permanently disable the Cloud9 IDE as I assume it uses a bit of CPU in the background monitoring port 80 (and hence more heat).
  • Put cpufreq-set -f 1.176GHz in your /root/.bashrc.local file.
    Type:
    scst cloud9.service
    scst cloud9.socket
    scdi cloud9
    Ignore error messages.
  • many thanks.... done
  • Having done the above my /root/.bashrc.local file looks like this;
    export PROJ=~/Beagle_SDR_GPS
    #export PATH=$PROJ:$PATH
    if [ -f ~/.bashrc.local.common ]; then
     . ~/.bashrc.local.common
    fi
    But the BBAI still starts at 1.5Ghz. If I log into the BBAI as debian, it immediately drops to 1.2GHz
  • edited September 2021
    @Gibsonmb you can add this command to crontab and it will start after any reboot, for example type sudo systemctl enable cron && sudo crontab -e and add to the end of cron file:
    @reboot sleep 10 && /usr/bin/cpufreq-set -f 1.176GHz > /dev/null
