Can't install 1.439 [fixed in v1.440]
I can't install 1.439 on my BBAI. It is not recognized from Admin page update check, and also the manual way (make stop, git clean -fd git checkout . , git pull -v , make clean , make , make install , make start) doesn't end up with 1.439, but with a normal running 1.438 (it's there http://erserver.ddns.net:8073/ ). No error during build process.
Is there really 1.439 out, or might my BBAI somehow be corrupted? If it is ... I now what to do. However, it would be nice to have a backup on SD-card for the next time, but the backup function still fails on BBAI. It would be great if you could put this on the list.
Thanks!
Eckhard
Hi Eckhard,
the reason is not the BBAI, I think. I'm seeing something similar with my normal BBG Kiwi. As I'm still running 1.437, update check is reporting 1.438 as the newest available version.
Ah, ok, thanks. So I'll wait before completely reinstalling my BBAI.
Eckhard
I had to stop the distribution of v1.439 shortly after it went out.
On the few Debian 7 based systems we have remaining the build produces a binary that crashes in a very strange way. It would leave these Kiwis bricked if I let the update continue. So I need to fix this. Normally I test on a Debian 7 system before release, but of course I didn't this time..
Works now, thank you very much!
Eckhard
Okay, should be good now. v1.440 is released which I tested on a BBAI here.
