KiwiSDR on wifi
Got my Kiwi to connect to my local wifi network. But it seems it is treating the wifi connection (wlan0) as a non local connection, even if ip adresses are local. Local network 192.168.1.X. Kiwi is given 192.168.1.225 by dhcp.
How to treat the wifi connection as local?
Wifi connection seems a better choice as less chance of hash via the ethernet cable and only the 5 V supply to consider.
73 de Olaf - LA3RK
73 de Olaf - LA3RK
But there is no support from me for WiFi in general. Too many problems getting WiFi to work as demonstrated by the hundreds of posts on this forum.
CONSOLE: only available to local admin connections
Can connect to kiwi both as listener and as admin, but "CONNECT" on console page states that I am not on a local connection. But as long as I can connect via ssh it should be ok.
Understand the missing support on wifi as it has a number of problems.
Any advice?
Create a file called check_start_wlan.sh in root's directory ("/root/check_start_wlan.sh") Change the "your_wlan0_connection_string" for your particular wlan0 connmanctl connection string
then as root:
crontab -eAdd this line to the end of the crontab:
*/10 * * * * /bin/bash /root/check_start_wlan.shmake sure to add an empty line after that line, then save/exit.
Verify the crontab looks sane
crontab -lThis should every 10 minutes via cron: check the output of ifconfig, look for the line starting with "wlan0", get the next line and check if there's a valid IP address present (checking if the "inet" phrase is present), if "inet" not present then ask connmanctl to connect that connection.
Note - only tested in my head, error conditions not trapped, running scripts as root creates a theoretical security risk etc etc etc.
Happy to take suggestions/improvement
I will try to implement your suggestion, first checking that the script works as intended.
Thanks again!
Nick
